Sponsored by: CARiD
Upgrade Advice 1985 Yota
Old Feb 9, 2011 | 09:43 PM
Airo Spade's Avatar
So about to start on my next project for my truck
heres my parts list Im buying all of this on monday so if you have any suggestions of what to,not or instead buy please let me know
1982 supra AFM
3" air filter not sure which one to get?
5M-GE throttle body also comes with new TPS which I already need
DOA 270 cam shaft
headman header
http://www.jegs.com/i/Hedman/500/39490/10002/-1
then If i get this what tubing will i have to get to complete my exhaust?
Aussie Locker
1500 chev leafs in back
and i cant figure out which leafs to get up front
TOYOTA HIGH STEER CROSSOVER STEERING KIT or is there a cheeper way?
looking for a brush gaurd or a bull bar in front
and MR2 1985 seats
Old Feb 9, 2011 | 09:45 PM
87hillbillyoter's Avatar
either RUFs or all-pro leaves up front. sounds like you got quite the project goin!
Old Feb 9, 2011 | 09:50 PM
Airo Spade's Avatar
I was on pirate and was told off in so many words for trying to figure out what all do you need to do for RUF's
Im also thinking of doing the wagoneer 7 leafs in front and to finish it off 31 x 12.5 x 15 but will those fit on my stock rims or what rims from another car would i have to get
Old Feb 10, 2011 | 01:32 AM
myyota's Avatar
Don`t go any bigger the 2 1/4'' on the exhaust pipe. When you do the throttle body swap post some pictures, im interested in seeing how it fits and if it will work or not on a 22RE.
Old Feb 10, 2011 | 01:42 AM
Airo Spade's Avatar
Ill be posting an entire how to for my entire swap dont worry, with tons of pics. So far Iv adjusted the valves, swapped plugs with hotter burning and done the MAF/Battery Swap. Hopefully I get this all done this or next weekend. I just need more advice on how much to trick the MAF enough for what Im doing to get the right tune and how to set the timing just right. Hopefully with all these small mods I might be able to see 150-175 HP and Ill have a dyno at the end for everyone since this is about as far as you can go before getting really deep. Unless Im missing something.
Old Feb 10, 2011 | 01:51 AM
myyota's Avatar
If you got the correct AFM its lug and play and you don`t need to adjust it at all, leave it at the stock setting. The part number for the AFM is 22250-43110, if its a different number it won`t work. I don`t think you will be anywere near 150-175 HP, i think you will be lucky to see 130-140 HP. But that all depends on the size of the tires and the gearing you have.
Old Feb 10, 2011 | 03:08 AM
Airo Spade's Avatar
It is plug and play but since I am running hotter plugs I need the ecu to shove more fuel in there and then because of everything else Im doing 60mm throttle body non slider linkage along with a 2.5"x2.0" AFM off the 7M-GE 1982 supra. Air flow will greatly incresce along with if somehow my cat gets ripped off. But then I run into do I need that back pressure from it. Also on a side note since Im going to have all of this off how hard is it to remove the EGR valve
Old Feb 10, 2011 | 03:09 AM
Airo Spade's Avatar
and its all stock other then the LT235x75R15
Old Feb 10, 2011 | 08:08 AM
rattlewagon's Avatar
For the RUFs you need 2 stock toyota packs. The rears have a softer spring rate, so you need to beef them up with the other pack. You just have to play with the leafs to make your own pack that works for you. RUfs are known for being low and flexy.
You also might have to weld on a new spring hanger. The stocks ones are not very strong, and will help with your pinion angle. Bannana shackles might be necessary to account for the longer springs, or you could weld the hanger a inch forward than stock. Should increase your wheelbase by 2-3 inches.
Pirate has a load if info on it. But as you found out, Just read dont post.
Old Feb 10, 2011 | 10:33 AM
Airo Spade's Avatar
I post it just involves a lot of swearing. So use the old fronts in combination with the backs or just buy another set of backs for the front and call it a day and weld and mil some metal together.
Old Feb 10, 2011 | 12:31 PM
2 sets of rears would be best, But the idea of RUFs is to work with what you have aka cheap.
There are lots of companies (sky and TG off the top of my head) that make hanger kits.
Old Feb 10, 2011 | 12:53 PM
Outsane's Avatar
I got a set of Mr2 seats.. I can sell..
Old Feb 10, 2011 | 12:59 PM
myyota's Avatar
When you install the supra AFM you will be flowing a lot more air, so leave it stock and see how it runs, you can always open it up and richen it up a couple of notches if needed. I was thinking, you might have to have the inlet of the upper intake bored out because of the larger throttle body.
Old Feb 10, 2011 | 01:56 PM
Airo Spade's Avatar
to everyone that posted
cheep is what Im going for but I cant seem to beat the 500-600 range for 4 leafs and 4 shocks and a hi steer.
For the supra intake Its 30 min north and the same place I'm getting the throttle body from and the supra has the 3" inlet intake that i want if i want to put a snorkel on, and for the intake being to small.
Read these
http://www.22rte-trucks.com/simplema...p?topic=1053.0
http://www.celica-gts.com/forums/index.php?topic=7543.0
Iv done my homework
Old Feb 10, 2011 | 02:14 PM
Black_1985_SR5's Avatar
just dont get the hedman header i had one it always wound up leaking at the flange
Old Feb 10, 2011 | 02:33 PM
Airo Spade's Avatar
what should I get then? and couldnt I just get a better gasket?
Old Feb 10, 2011 | 02:36 PM
any sort of longtube one piece header just stay away from the two piece one, i couldn't see the one on the link it wont work for some reason
Old Feb 10, 2011 | 03:58 PM
myyota's Avatar
How much lift are you trying to get ?, and do you have a truck or 4Runner ?.
Old Feb 10, 2011 | 04:17 PM
Airo Spade's Avatar
just 3" nothing special and possibly 1" body for ˟˟˟˟s and giggles just want to do it. I also redid my math around $475 right now for the lift kit. Is there a truck with shock absorbers that I can strip?
Old Feb 10, 2011 | 04:22 PM
SpecialScottie's Avatar
RUF and chevys work well
