Sponsored by: CARiD
Trying to start 96 4runner 3.4L SR5
Old Sep 22, 2018 | 02:35 PM
Tyler2494's Avatar
Battery is new an fully charged when trying to start all i get is a rapid clicking sound like a machine gun
Old Sep 23, 2018 | 08:32 AM
thefishguy77's Avatar
Welcome to the board. Start with giving use some back story. Has the rig been yours the whole time? What symptoms, if any, did it present before it had a problem? Are there any stored codes in the computer? Automatic or manual transmission? How many miles on the rig? What aftermarket electrical work has been done, LED's, Winch, Stereo, etc.?
Old Sep 23, 2018 | 09:24 AM
wyoming9's Avatar
Red face
Best guess is a poor connection Might be at the battery
Might be a poor ground connection
Might be the solenoid is in need of some attention
Old Sep 23, 2018 | 05:42 PM
Co_94_PU's Avatar
A rapid click is a relay closing and opening due to voltage drop. Voltage drop occurs because of poor connection (dirty, loose), or failing wiring due to the resistance increase (heat) while trying to carry current.
Get your volt meter out. Measure across battery posts, across battery cables, from battery negative post to distribution block for starters.. You want to start at the battery and work your way all the way down to the starter contacts (both solenoid wire, and primary).
Likely causes are the battery cable terminals, fusible link wire, starter relay, ignition switch, starter primary wire, starter solenoid, or any of the wires between any of those components..
zanestoy
Mar 22, 2015 05:37 AM
hazelwod
Dec 15, 2009 10:56 PM
Teva02
May 7, 2007 09:05 PM
ErikJeanna
25
Nov 22, 2006 12:49 AM
98Tacoma
7
May 29, 2003 12:30 PM
