Trying to start 96 4runner 3.4L SR5
Battery is new an fully charged when trying to start all i get is a rapid clicking sound like a machine gun
Welcome to the board. Start with giving use some back story. Has the rig been yours the whole time? What symptoms, if any, did it present before it had a problem? Are there any stored codes in the computer? Automatic or manual transmission? How many miles on the rig? What aftermarket electrical work has been done, LED's, Winch, Stereo, etc.?
Best guess is a poor connection Might be at the battery
Might be a poor ground connection Might be the solenoid is in need of some attention |
Originally Posted by Tyler2494
(Post 52408662)
Get your volt meter out. Measure across battery posts, across battery cables, from battery negative post to distribution block for starters.. You want to start at the battery and work your way all the way down to the starter contacts (both solenoid wire, and primary). Likely causes are the battery cable terminals, fusible link wire, starter relay, ignition switch, starter primary wire, starter solenoid, or any of the wires between any of those components.. |
