Sponsored by: CARiD
Transfer case fluid
Old May 18, 2021 | 03:50 PM
Marine77's Avatar
Transfer case fluid
What can I substitute for 75w gear oil?
Old May 19, 2021 | 10:53 AM
2ToyGuy's Avatar
All depends. What does the book call for? What year, what transfer case number, which engine.? Help us help you.
I would suspect that 80W-90, or if you can find it, straight 90 weight. The things to consider are the normal operating temperature range, and what the FSM specifies. The really important thing, from what I understand, is the GL- rating. GL-4 or GL-5. I believe the transmission (if it's a manual) and transfer case need to have GL-5, and the differentials need the GL-4, but I might have that bass-ackwards. Terrible memory.
Does that help any?
Pat☺
Old May 19, 2021 | 11:56 AM
Marine77's Avatar
2017tacoma 4x4 auto.
Old May 20, 2021 | 11:20 AM
2ToyGuy's Avatar
Ok, all depends on the temperature range you're going to be seeing. Only using it in the snow and ice? Lower weight oil is better. 80W, or 80W-90, something like that. When I lived in Yuma, AZ, a VERY hot place, I used 90W-120 in the transmission and differentials. It worked great.
Most important, through, is the GL rating. GL-5 for the transfer case, GL-4 for the differentials.
Does that help at all?
Pat☺
dirtroads_33
Aug 6, 2013 08:07 AM
skoti89
Apr 2, 2011 04:38 PM
ultimase
Feb 16, 2011 03:28 PM
havic
Nov 27, 2004 07:51 PM
