Sponsored by: CARiD
too much oil?
Old Mar 26, 2010 | 12:41 PM
khamblin's Avatar
too much oil?
Hey I just did my first oil change on my 1990 22re. I followed the manual, and it said to put 3 or 4 liters in and let it run for a minute then check the level and if it was still low put another 1 liter in. So it was still lower so i put another liter in and it was perfect, at the full line. Next day I went out and just before taking off checked the oil, and now it's above full. So it must have registered more as i drove it around, or something. So is it bad to be above the full line? Will that do damage? Should I drain a little out?
Thanks
Old Mar 26, 2010 | 12:44 PM
pruney81's Avatar
I always put a little bit more in my 22re. The manual calls for 4.5 quarts with the filter and I always end up using about 4.8 or so. Unless you are multiple quarts over you should be fine. I'm not sure liters coorelates to quarts so maybe you can fill me in on that one.
Old Mar 26, 2010 | 12:46 PM
Fink's Avatar
4.8 quarts equals roughly 4.5 liters.
Fink
Old Mar 26, 2010 | 12:47 PM
khamblin's Avatar
Ok thanks, good to know. I don't want to wreck it or something. But if it's acceptable to have a little more thats good. I'm pretty sure a quart and a liter are basically the same. Thanks
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
