Sponsored by: CARiD
third members with 5.29 gears
Old Mar 2, 2011 | 06:25 AM
yotarunner89's Avatar
im new to the lifted truck world and just bought a 1989 4runner v6 stock 4.10 gears. running 35" tall tires and want to put 5.29 gears in but everywhere i look for complete third members all i can find is third members for my 8"rear end none for the 7.5" ifs front end. anybody know where i can find third member for the front? or do i have to just buy gears and put them in my self?
Old Mar 2, 2011 | 06:48 AM
badattitude's Avatar
is this what you are looking for:
http://www.justdifferentials.com/ind...oducts_id=2572
Old Mar 2, 2011 | 06:53 AM
yes it is thank you do you know of any cheaper places?
Old Mar 2, 2011 | 07:02 AM
at davezoffroadperformance.com i can find the rear third member for $375.00 for 5.29 gears
Old Mar 2, 2011 | 07:27 AM
The only other diff shop I'm aware of offering the front is east coast gear.
http://eastcoastgearsupply.com/i-157...clamshell.html
However, I don't think this one is for your truck because it has reverse cut gears?
But, I bet you can call around and ask if they will build a front for you. I assume they will build one for for you even if they don;t show it on their site.
Also, you may be able remove the front thrid from your truck and send it in to be be rebuilt. If you send yours in it may save money. I bet you can call any of the diff shops like daves, randys ring and pinion, inchworm gear or jawsgear and ask them if they will rebuild and install gears in your front third. I think they would?
Shipping will run about $70-$90 each way
Sepratly, I suggest you consider a locker or limited slip unit in the rear. If you have the tires and gears might as well add the locker or LSD while you're at it. just my .02
Old Mar 2, 2011 | 10:02 AM
scuba's Avatar
Correct. Thats for a Tacoma.
Old Mar 3, 2011 | 06:21 AM
so i contacted davezoffroadperformance.com and he said $400 but im waiting to hear back from them cause he didnt explain if that was to be sent in and be regeared of if it was for a complete unit. the rears are $400 for the hole third member so i dont know but thanks for your help ill keep you posted when i get more info.
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
coffey50
Jul 28, 2015 10:55 AM
