Sponsored by: CARiD
They say go BIG or stay home
Old Apr 25, 2011 | 07:56 AM
1993jumper's Avatar
Cool They say go BIG or stay home
Gotta go. my new 22RE is not right Im tired of messing with it. So a small block chevy 400 is in the works anyone have any experience with these swaps? what all is entailed with this. This is going into my 93 2wd truck. any advice would be very helpfull. Thanks Jim.
Old Apr 25, 2011 | 08:50 AM
WHEELER8688's Avatar
your definatly going big with that 400, go to the engine swap section and you can find info for these swaps
Old Apr 25, 2011 | 08:56 AM
1993jumper's Avatar
BIG is better 2.4L to 6.6 gonna be a ride!!
Old Apr 25, 2011 | 09:07 AM
Fink's Avatar
Moved to the Newbie Tech Section.
As WHEELER said, do a search and narrow it down to the Engine Swaps section and you should find a ton of info about various domestic swaps.
Fink
Old Apr 25, 2011 | 09:10 AM
blake.nemitz's Avatar
i would use that motor with a chebby 2wd tranny like a th350 or something like that to make it easy.
xxxtreme22r's Avatar
IMO that 400 even in stock form is gonna be way too much for that 7.5" rear end. Can't say about the trans though. If auto I would lean towards definitely not. Manual mayyybeeee.
Old Apr 25, 2011 | 09:12 AM
1993jumper's Avatar
yea manual 5 speed my main concern is holding the weight in the front.
Old Apr 25, 2011 | 09:24 AM
Alberta4x's Avatar
Heavier springs in the front and you shouldn't have too many problems holding the weight of the motor.
Old Apr 25, 2011 | 10:36 AM
1993jumper's Avatar
Talking This is what I have to work with
Has a duel shock system. What new bars or coil overs
Old Apr 25, 2011 | 11:26 AM
Alberta4x's Avatar
If you're sticking with torsion bars, I'd get 26mm bars, with the weight of the motor they should ride nice and soft.
Old Apr 26, 2011 | 07:42 AM
1993jumper's Avatar
Pulled the 400 this morning
Old Apr 26, 2011 | 07:57 AM
I would at least get a racing clutch for your trans, if not then run a trans that was meant for that engine. I doubt even the HD marlin clutch will hold it for very long. Will probably be a little cheaper going with a GM trans as well.
Old Apr 26, 2011 | 08:01 AM
dropzone's Avatar
Fossilized
why are your shocks Fighting??
you have dual shocks
Old Apr 26, 2011 | 08:11 AM
1993jumper's Avatar
13" travel in the front 2" body lift.
Old Apr 30, 2011 | 06:50 AM
1993jumper's Avatar
Heads are done its time to reassemble.
Old Apr 30, 2011 | 08:25 AM
wii_tarded's Avatar
Old Apr 30, 2011 | 09:22 AM
Tofer's Avatar
Sponsor
Old Apr 30, 2011 | 10:02 AM
4x4climber's Avatar
what they said ^^^
Old Apr 30, 2011 | 10:37 AM
1993jumper's Avatar
Talking
You got it TOYOTA
Old Apr 30, 2011 | 11:26 AM
warpigg's Avatar
she looks purtty what are you gonna do for engine mounts?
