T100 1993 speedometer
Need help ts speedometer on my truck . Can an aftermarket speedometer been install on my truck . SO far I change the speed sensor ,no luck , 1993 have an electronic speedometer . I have a truck manual but is vague in the instrument cluster wiring . I also purchased an used cluster but returned due to be damage as well . My truck is std, v6 , 4x2 and is about to become a classic . But I have to guess my speed and don't like it . Try apps on my phone but is a hassle . Any help would be appreciated or suggestions .
You need to figure out just what the problem is.
The gear in the transmission might no longer be able to drive the sensor.
This happens and is by far the worst.
Bad sensor
Damage in the wiring to the cluster
The speedometer in the cluster might be damaged.
Yes you could go aftermarket as long as the problem is in the speedometer.
Bad sensor
smilen724
13
Nov 8, 2015 04:11 PM
kcaudill
Oct 10, 2015 02:39 PM
Phantez
Sep 30, 2015 08:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
