Sponsored by: CARiD
T-stat replacement!!
Old Mar 24, 2011 | 11:49 AM
sq2124's Avatar
i have an 94 toyota pick up 22re 2wd 4 cylinder and just want to know how to change my thermostat. i dont know where its located and would love to get all the help and advice i can get. thank you!
Old Mar 24, 2011 | 11:59 AM
ChefYota4x4's Avatar
Hey man, I hear ya. I'm pretty sure the 94 should be the same as my 87. The thermostat is on top of the intake, to the right of/behind the throttle body. Two bolts hold it in.
I will find you a picture and post it up for ya. Just for your information, most people feel, on this site and most others for Toyota, that the Toyota Thermostat is the way to go. Definitely a dealer is the best option part.
Old Mar 24, 2011 | 12:07 PM
Here you go..... it takes a lil finagling and turning it at angles to get it out just right, but you'll get it. DON'T USE ANY SEALANT! Just use the o-ring it comes with, k? >>>
the orange circles are where the two bolts(12MM) that have to be removed are.
Old Mar 24, 2011 | 12:09 PM
rhill's Avatar
#5 is your thermostat and #6 is your housing. I don't have a 22re so I can't really tell you exactly how to replace it...but I'm pretty sure you just unbolt the housing and pop the new one in there?? Definitely go with an OEM thermostat, and maybe pick up a Haynes manual while your out shopping. Also not a bad idea to replace radiator hoses and flush the coolant while you're in there if you have time.
Old Mar 24, 2011 | 12:22 PM
YEP, ...if those hoses are hosed, toss em, lol. BTW, rhill, .... what diagram is that for, a 22re??? If so, i didn't know the mounting, etc. was so different in different years.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Poncho0206
Jul 10, 2015 06:21 PM
