Sponsored by: CARiD
Stuttering at 3500 rpm in 02 4runner
Old Dec 21, 2009 | 06:56 AM
milehi's Avatar
Hi, I replaced the plugs and wires about a week ago and I am getting stuttering around 3500 rpm. I am also getting a hard start once in awhile, especially after having the key on. It starts eventually but kicks out a bunch of white smoke. I took it to Midas to get it looked at, but did not have half a day to leave it there. They thought it sounded like a bad injector. Is there a way to check if an injector is bad? How easy is it to replace an injector?
Old Dec 21, 2009 | 08:53 AM
brian2sun's Avatar
White smoke does not usually indicate a bad injector, it usually indicates a head gasket leak. Smell your exhaust when you first start it and see if it smells sweet. Any water coming out the tailpipe (besides after startup for a few minutes - that is normal)? It sounds to me like Midas is making wild guesses, so bring it to a full service shop and have them look at it. They can test your injectors, but it sounds like you should have them do a compression and a leak-down test. How is your coolant level in the overflow and the radiator? Any milkshake in the oil or coolant?
Old Dec 22, 2009 | 10:16 AM
zach@sparkplugs.com's Avatar
milehi, you've probably already done this, but double check your wires, make sure that they're definitely fitting onto the plug, a lot of times you'll feel a nice little snap when it geos onto the plug. Are they gapped correctly? Also, what part number are your plugs?
Old Dec 22, 2009 | 11:25 AM
Elton's Avatar
i hope you used ngk or denso plugs and wires these toyota's dont care for anything else
Old Dec 22, 2009 | 05:07 PM
brian2sun's Avatar
The dual electrode plugs are not supposed to be gapped before install. The gap on our plugs are .43 or .44 from the factory, but each electrode's gap is 1/2 that so .22 per side. I remember reading on NKG's site (and on threads here on YT) that if you try to gap these plugs you'll have problems.
Old Dec 22, 2009 | 05:46 PM
Elton's Avatar
yea ive changed the plugs twice on my truck using factory denso's with no problems just putting them in right from the box
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
88runnergomas
Jul 9, 2015 01:12 PM
shar
Jul 9, 2015 12:38 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
