Spun Rod, Main Bearing
1995 4runner - v6 ..i am almost postive i have spun a a main bearing..but i could have thrown a rod, now i havepriced parts for both problems....but if i build a rebuild kit, i have heard several estimates...the one i am asking about is.....the machining,,...what all would have to be done? my labor will be done free...so what should cost for this be???? any ideas..
brian TN
brian TN
If you threw a rod I would be looking for a replacement engine. The rod more than likely cracked or broke the block. The piston can contact and bend the valves. best thing to do is tear it down and determine the extent of damage and have a machine shop look the parts over before ordering parts. If you are on a budget the used engine is the least expensive.
he's gone
7
Dec 3, 2019 07:08 AM
Iceman4193
Aug 28, 2015 08:43 PM
