Sponsored by: CARiD
Spare tire not coming off
Old Dec 28, 2006 | 06:18 PM
LiveAdventure's Avatar
I need to put my spare tire on but not sure why the tire is not coming down. 96 4runner sr5 4x4. I had to twist the round button with pliers to get it loose but cant get the tire off? I really need help to get it back to my house and to work. Friend drove car to airport, spun out, and blew out front right tire.
Thanks
Old Dec 28, 2006 | 06:40 PM
Tanto's Avatar
Don't use pliers. Use the tool that is with your factory jack.
Soak the mechanism for lowering the spare in PB Blaster overnight then give it a whirl. Rust is likely the cause of the issue you're dealing with and it's a good idea to operate it a little bit every now and then to prevent this happening again.
Then tell your friend what a jack*** he/she is.
Old Dec 28, 2006 | 06:55 PM
Hmm... i thought i had my jack and everything but maybe not? Can you desribe what this tool looks like? or maybe a link where i can buy one? Thanks
Elton's Avatar
yep use the tool under the back seat mine has never been used and it it worked great
Old Dec 28, 2006 | 07:12 PM
SLC97SR5's Avatar
Are you twisting the spring from underneath the truck?? If so that is NOT where you lower the tire. Find the long tubular rod under the back seat and pop the rear hatch, insert the rod until you bottom out on the hole then crank away.
The spring loaded button keeps tension on the tire to keep it from rattling.
Old Dec 28, 2006 | 07:21 PM
So where am i insterting the long rod? It is the one that you use for the jack as well, correct? Thanks.
Old Dec 28, 2006 | 07:24 PM
CJM's Avatar
CJM
Right under the bumper, you will see a cut out for it. The diagram withthe jack should explain it or the manual will.
Old Dec 28, 2006 | 07:36 PM
Tanto's Avatar
There should be a slit directly in the middle where your tailgate/hatch meets the rear bumper. Put the end with the hook on it through that.
Old Dec 29, 2006 | 12:32 PM
Thanks for the help, went and took care of it early this morning.
94whiterunner
9
Sep 22, 2015 07:28 PM
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 8, 2015 12:05 AM
