Sponsored by: CARiD
So I need a lift kit
Old Oct 18, 2006 | 09:08 AM
dumpedeg6's Avatar
I just bought some 33x12.50x15 BFG AT tires with Toyota alloy wheels and I want to put them on my 1996 4Runner 4x4. I have been looking around for lift kits so I can fit these tires and I see coil spring kits and spacer kits as well as combinations of coils/spacer kits. I was wondering what the differences are in the spacer and coil kits etc... and if I will need to buy aftermarket shocks as well. And if anyone knows of any good places to get these kits any information is greatly appreciated. Thanks in advance!
EDIT: Please forgive me, I'm a newb
Old Oct 18, 2006 | 09:15 AM
NPE701's Avatar
OME suspension will give you 2 - 2.5 inches... I am guessing you'll still need some body lift with that to fit 33's.
These guys have good prices on OME stuff: www.rocky-road.com.
Old Oct 18, 2006 | 09:22 AM
spaugh's Avatar
Try the search button. I searched for "3rd gen lift" and came up with 500 hits.
Long story short, you are gonna need about 4 inches of lift. 2-3 of suspension lift, and 1-2 inches of body lift.
good luck.
EDIT: You are gonna rub with that wide of tire on your A arm and or frame unless you have some aftermarket arms or correct backspacing on the wheels. And are you sure the 15" wheels are gonna fit over your brakes?
Old Oct 18, 2006 | 09:24 AM
mastacox's Avatar
Are you sure those 15" rims will fit on your 4runner? What size rims does it have right now?
Old Oct 18, 2006 | 09:25 AM
dumpedeg6's Avatar
Thanks for the replies!
Old Oct 18, 2006 | 09:26 AM
dumpedeg6's Avatar
It has 15" rims as it is at the moment.
Old Oct 18, 2006 | 09:29 AM
mastacox's Avatar
Cool, just making sure.
Old Oct 18, 2006 | 09:59 AM
dumpedeg6's Avatar
What about this spacer kit here... http://nitrousenterprises.com/4runnerkit.html
Old Oct 18, 2006 | 10:06 AM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
Considering they talk about x-reas (only on 2003 + 4Runners) It doesn't seem like its designed for the 1996-2002 4Runners
Old Oct 18, 2006 | 10:17 AM
Stevo3's Avatar
Yep, your going to rub your upper a-arm with that wide of tire. And even if you had the 11.50 i would think you would rub too with the stock rims.
I put a 3'' toytec spacer lift with 03 tacoma coils on to get the true 3'' with a 1'' diff drop. Got 285/75/r16's goodyear mt/r's and i only rub if im doing some serious rompin.
I would recommend getting some new rims. even then you will be close with those tires.
Heres mine https://www.yotatech.com/forums/show...t=finally+pics
Old Oct 18, 2006 | 12:43 PM
neliconcept's Avatar
a 1/4 inch spacer will take care of the upper a arm rubbing.. stock rims and AT tires wont rub the a arms. mt tires will though
Old Oct 18, 2006 | 01:05 PM
97Limited's Avatar
Check out these Lift Kits from Steve!!
www.sonoransteel.com
I have the Kit #1.5 on my 97 4Runner!!
Old Oct 18, 2006 | 05:31 PM
KyleT's Avatar
x2
i have the #1 kit.
Old Oct 18, 2006 | 05:46 PM
4unner4life's Avatar
In my opinion, the #1 kit is the best all around kit offered. In the next few months, I plan on doing that kit and a 1inch body lift along with 33x12.50 bfgs with some black steelies. The key to fitting those tires will be clearing them of the A-arms, so get some 15x8 rims with the correct backspacing.
Old Oct 18, 2006 | 05:56 PM
Bob_98SR5's Avatar
why dont you search "nitrous enterprises" and see why its important to search instead of being spoon fed
Old Oct 18, 2006 | 07:14 PM
dumpedeg6's Avatar
I already did that earlier after posting that link and I will not be ordering anything from them. Thanks for your helpful input Bob...
Old Oct 18, 2006 | 07:29 PM
Bob_98SR5's Avatar
assuming you are not being facetious, you are welcome.
Old Oct 19, 2006 | 01:25 PM
dumpedeg6's Avatar
So you guys are saying the tires will rub just driving around? Or if I want to flex and go off roading and what not they will rub?
Sep 4, 2015 09:27 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
