So I need a lift kit
I just bought some 33x12.50x15 BFG AT tires with Toyota alloy wheels and I want to put them on my 1996 4Runner 4x4. I have been looking around for lift kits so I can fit these tires and I see coil spring kits and spacer kits as well as combinations of coils/spacer kits. I was wondering what the differences are in the spacer and coil kits etc... and if I will need to buy aftermarket shocks as well. And if anyone knows of any good places to get these kits any information is greatly appreciated. Thanks in advance!
EDIT: Please forgive me, I'm a newb :cry2: |
OME suspension will give you 2 - 2.5 inches... I am guessing you'll still need some body lift with that to fit 33's.
These guys have good prices on OME stuff: www.rocky-road.com. |
Try the search button. I searched for "3rd gen lift" and came up with 500 hits.
Long story short, you are gonna need about 4 inches of lift. 2-3 of suspension lift, and 1-2 inches of body lift. good luck. EDIT: You are gonna rub with that wide of tire on your A arm and or frame unless you have some aftermarket arms or correct backspacing on the wheels. And are you sure the 15" wheels are gonna fit over your brakes? |
Originally Posted by dumpedeg6
(Post 1016603)
Thanks for the replies!
Originally Posted by mastacox
(Post 1016611)
Are you sure those 15" rims will fit on your 4runner? What size rims does it have right now?
(Post 1016613)
It has 15" rims as it is at the moment.
What about this spacer kit here... http://nitrousenterprises.com/4runnerkit.html
(Post 1016653)
Yep, your going to rub your upper a-arm with that wide of tire. And even if you had the 11.50 i would think you would rub too with the stock rims.
I put a 3'' toytec spacer lift with 03 tacoma coils on to get the true 3'' with a 1'' diff drop. Got 285/75/r16's goodyear mt/r's and i only rub if im doing some serious rompin. I would recommend getting some new rims. even then you will be close with those tires. Heres mine https://www.yotatech.com/forums/show...t=finally+pics |
a 1/4 inch spacer will take care of the upper a arm rubbing.. stock rims and AT tires wont rub the a arms. mt tires will though
(Post 1016603)
EDIT: Please forgive me, I'm a newb :cry2: www.sonoransteel.com I have the Kit #1.5 on my 97 4Runner!! |
Originally Posted by 97Limited
(Post 1016813)
i have the #1 kit. |
In my opinion, the #1 kit is the best all around kit offered. In the next few months, I plan on doing that kit and a 1inch body lift along with 33x12.50 bfgs with some black steelies. The key to fitting those tires will be clearing them of the A-arms, so get some 15x8 rims with the correct backspacing.
(Post 1016653)
Originally Posted by Bob_98SR5
(Post 1017089)
why dont you search "nitrous enterprises" and see why its important to search instead of being spoon fed ;)
(Post 1017163)
I already did that earlier after posting that link and I will not be ordering anything from them. Thanks for your helpful input Bob...
assuming you are not being facetious, you are welcome. |
So you guys are saying the tires will rub just driving around? Or if I want to flex and go off roading and what not they will rub?
