Sponsored by: CARiD
routing of longer brake lines
Old Jan 19, 2012 | 08:47 PM
Whitie's Avatar
I have a good 3ish in the front lift but cant seem too route the extennded brake lines I have with out rubbing am I twisting them wrong
Also I am running new install chevy rears with the load spring 2000 miles and still looking up in the front can I take a leaf out and add a longer shackle in the front would that be a good swap too add more flex... I have old school hoops and 13.5 travel shocks
(4.5 down and the rest up) , guessing rancho springs this is all the front stuff
thanks whitie
I have no problem swapping out leaves too make stuff flex
Old Jan 19, 2012 | 09:34 PM
4Crawler's Avatar
I run my front brake lines through a small spring loop attached to the frame. That keeps them pulled back normally but lets them extend farther under full droop:
More photos:
- http://www.4crawler.com/4x4/4R_suspe...#CustomSprings
Old Jan 19, 2012 | 10:33 PM
Whitie's Avatar
Thanks I will reroute bake lines and most likely swap in some thinner leafs and add some more shackle for more flex and lower the truck so I can take out my chevy load spring my next problem is making my x over steering from trail gear not rub . "I think the vee blocks are messing me up"
Brian
chukarhunt
Dec 8, 2019 11:39 AM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
Nickdigg
Jul 7, 2015 06:04 AM
