replacing shock bushing?
Old 02-02-2010, 03:18 PM
netmasta88's Avatar
hey guys, i just found out that the bushing on my front shock is worn out, i have a 2002 tundra trd, with bilstein shocks in the front, i was wondering if its possible to change the bushing instead of buying a whole new shock? and how hard is it to replace this bushing?
Old 02-02-2010, 06:31 PM
4Crawler's Avatar
I've replaced a bushing in a set of Bilsteins, or at least removed the bushing and put in a different sized sleeve:
So it is physically possible, the question is whether you can find a replacement bushing, give Bilstein custom support a call and see what they can come up with.
The Bils. bushings are different than others I have seen, Rancho shocks use a sort of hour glass shaped bushing, KYBs use a straight sided rubber bushing without the end flanges that the Bils. bushings have.
Old 02-03-2010, 02:20 AM
netmasta88's Avatar
what about universal bushings, there is a lot of them on the net?
Old 02-03-2010, 06:59 AM
4Crawler's Avatar
Measure what you need and see if any of them will fit. Energy Susp. might be a place to try:
- http://energysuspension.com/products...-Bushings.html
Or call up Bilstein, I've found their customer support to be awesome:
- http://www.bilsteinus.com/contact.php
Old 02-03-2010, 12:53 PM
netmasta88's Avatar
ok cool thanks!
Old 02-09-2010, 02:48 AM
netmasta88's Avatar
hey guys, i emailed bilstein and the guy said he can get them for me no problem, thanks guys!
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
andrewtexas123
07-14-2015 04:29 AM
akaphilly
07-09-2015 02:34 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: replacing shock bushing?
