Rear third member interchange
I have a 1993 toyota 4x4 with 3.0 auto, the rear diff is shot. It has 4.56 gears, code G254, 8" ring gear, 4.56 ratio, 4 pinion carrier. I have found a 1996 toyota 4 runner, 4x4, auto with 3.4 with rear diff code A04A, 4.56 gears, 2 pinion. Can I intall the 4 runner third member into 1993, i guess would they be interchangeable???
Yes you can interchange them if they are both indeed 4.56s'.
This page says there are no 2 pinion 3rds in '96+ 4Runner, all are supposed to be 4 pinon types like the earlier 'V-6 3rds.
http://home.4x4wire.com/erik/diffs/
This thread says A04A is 4.30
https://www.yotatech.com/forums/f2/axle-codes-54515/
Other sources indicate 'A code is 7.5" ring gear???
I don't know what to think.........
Here is another page that makes it even more confusing, Good Luck!!!
http://www.ttora.com/forum/2-early-t...axle-code.html
Thanks for the info, the G254 came off the 93, auto 3.0 and the code A04A is from the 96 4 runner, 3,4 auto. Maybe the codes don't match the 3rd member??? I guess the only way to tell for sure is to pull it out and compare visually. Chart I found for A04A is A: 7.5 ring gear, 04 4.56 ratio and A for 2 pinion. Would like to verify before doing the work. Any input will be greatly appreciated. I think they should interchange but I can't find a straight answer. Maybe I'll pull up web site to order rebuilt 3rd member for both and see what I get for the truck info
I pulled up East Coast Gear Supply and it lists 85-95 V6 Toyota pickup and 4 runners and 96-2009 4 runners without Elocker together as using the same 3rd member. I may call them tomorrow and maybe they will be kind and help me out.
I can say for certain that no '96 4Runner came from the factory with a 7.5" Rear end.
FRONT axle in 3rd gen Runners is 7.5" high pinion clamshell case type and requires reverse cut gears that are not suitable for ANY 7.5" rear 3rd member.
