Sponsored by: CARiD
Rear differential: Gasket or RTV?
Old Jun 11, 2011 | 01:49 PM
ESQ's Avatar
ESQ
Hi,
I'm replacing the third member in my 3rd gen runner and am wondering if it is best to install the 3rd member with:
a) a new gasket
b) RTV
c) Both
Thanks.
Old Jun 11, 2011 | 02:08 PM
Peterbuilt84's Avatar
I always just use rtv myself. Just make sure to give it time to cure before filling up the diff with gear oil.
Old Jun 11, 2011 | 02:14 PM
scuba's Avatar
RTV and RTV only.
Grey stuff is what I've always used. I generally put a bead of RTV on, install the diff and tighten the nuts a bit more than hand tight. Let it sit for an hour or 2 and then properly torque the diff in.
Old Jun 11, 2011 | 03:01 PM
ESQ's Avatar
ESQ
Thanks for the quick replies. I am curious as to why, though?
Old Jun 11, 2011 | 05:42 PM
corax's Avatar
Either will work just fine, I wouldn't do both. If there are any nicks or scratches on the mating surfaces RTV will fill them in and seal a bit better. If the mating surfaces are flat and smooth, paper gaskets make it easier to pull off later as well as easier to clean the gasket surfaces.
I've always used black RTV just because I never seem to have a gasket handy when I need one
Old Jun 27, 2011 | 11:09 AM
ESQ's Avatar
ESQ
Well I got it all back together and WOW. I love the 5.29s. The truck just pulls and the highway RPM aren't bad at all. Holding power on the hills has been restored and then some. It stays in OD
But 3 days later, the front passenger CV axle/diff seal is now leaking. Should have replaced it at the time. The seal looked good when I inspected it, but alas. Out she comes again...
Does anyone know the diameter of a socket or whatever that I can use to knock in the seal?
Old Jun 27, 2011 | 11:20 AM
waskillywabbit's Avatar
Pulling front IFS diffs brings the suck.
I use Toyota RED or Toyota BLACK on everything.
:wabbit2:
Old Jun 27, 2011 | 11:21 AM
INFINITY's Avatar
Originally Posted by scuba
RTV and RTV only.
X2. all i use is ultra gray. i hate leaking fluids that's why i use gray and clean the crap out of the surfaces.
Old Jun 27, 2011 | 11:31 AM
MaK92-4RnR's Avatar
I used ultra blue on front and rear diffs... holds up just as good, but looks a little cooler
Old Jul 16, 2011 | 03:37 PM
NCalDyer's Avatar
i used a fel-pro paper gasket with coppercoat, worked amazingly
Old Jul 17, 2011 | 12:03 AM
myyota's Avatar
I used ultra black on both third members on my 4Runner and ive never had a problem.
Old Jul 17, 2011 | 10:42 AM
Philbert's Avatar
I used RTV Grey and a felpro gasket on my rear diff and it's been dry for years (check out my DIY in my sig ).
Old Jul 17, 2011 | 11:10 AM
MudHippy's Avatar
http://permatex.com/documents/PX-0378.GearOilRTV.SS.pdf
http://permatex.com/products/Automot...tv_sealant.htm
I haven't found it anywhere locally yet. Just online. Whatever color RTV works alright though. I've used many of them for it. I didn't end up being totally satisfied with how Ultra Black held up(~2 years before my rear axle devoloped a micro-leak). But if it was all I had, I'd use it again. I've been trying out the Ultra Copper to see if it's any better for that application. It's been workin' good for about a couple years so far. Who knows?
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Iceman4193
Jul 15, 2015 04:48 PM
Coreyr384
Jul 10, 2015 11:13 AM
