Rear axle leak?
Old 11-03-2008, 12:22 PM
MurphyzRunner's Avatar
Rear axle leak?
I have an 85 runner with a 93 rear axle with a lockrite locker, 456 gears and sky's rear disk...I have had the axle on the truck for 3-4 months and some decent offroad trips, the truck has been sittin for about two weeks and on both rear tires on the inside by the brakes I have a leak..a decent leak so I checked the brakes and it looks like there fine truck drives and stops and is still full of fluid the kid I bought the axle said it had less than 500 miles on the locker and gears so this may be a dumb question but what seals do you think are leaking and do I have to pull the axles out to change them? it looks like gear oil more than brake fluid and is there some kind of stop leak or should I just pull the brakes off tear into it?
Old 11-03-2008, 12:30 PM
4Crawler's Avatar
Likely both the inner and outer seals are leaking if oil is making it out to the brakes:
http://www.4x4wire.com/toyota/mainte...axle/oil_seal/
Might check to see if your diff. breather is clogged, if so that can let pressure build up and force oil out past the seals.
Old 11-03-2008, 12:31 PM
904_runner's Avatar
The inner seals are easy. the outer seals cannot be gotten to without taking off the wheel bearings which would most likely mean replacement. I would replace the inner axle seals.
Old 11-03-2008, 12:36 PM
Alright thanks man I check and see if the diff. breather is clogged but I'm guessing a seal...Is there any special tools needed mybe a puller or just rip them out and replace?
A2theK
01-10-2016 10:18 AM
jerusry
10-19-2015 05:28 PM
andrewtexas123
07-14-2015 04:29 AM
Avenged
07-09-2015 07:55 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Rear axle leak?
