Sponsored by: CARiD
rear 5-bolt cover leak?
Old Aug 31, 2013 | 10:04 AM
Streetgrinder's Avatar
I'm replacing my clutch, finally, and looking up behind the engine, I see a 5-bolt cover directly under the rear semi-circular seal of the valve cover. Something is leaking oil back there. I replaced the valve-cover seal a few months ago, but I don't trust those semi-circular seals. I used an OEM seal kit that costed the big bucks.
My question, if anyone knows, can that 5-bolt cover leak oil, or is it the semi-circular valve cover insert? Thanks.
Old Aug 31, 2013 | 12:52 PM
vital22re's Avatar
totally a bro
It leaks coolant. More than likely its the half moons on the head
http://www.google.com/imgres?imgurl=...9QEwAQ&dur=102
Old Aug 31, 2013 | 01:22 PM
Thanks Vital,
Do you use silicone on those half-moons or not? Any tricks on sealing them, they seem to leak no matter what.
Old Aug 31, 2013 | 03:16 PM
vital22re's Avatar
totally a bro
make sure to clean off any oil and old silicone with brake cleaner so its grease free, then silicone the round part and insert. Do this for both. Then put a light skim on top of the plug and reinstall the cover.
Old Aug 31, 2013 | 03:42 PM
Thank you. Will do.
Old Aug 31, 2013 | 04:52 PM
85toy4runner's Avatar
from 4crawler, It is the cooler for the exhaust gas coming from the exhaust ports to the EGR valve (called the EGR Cooler in my '85 FSM
interesting I to though it would have oil in there to but, vital22re is right in the pic here you can see the staining from the dreaded green anti freeze
Sep 4, 2015 09:27 AM
andrewtexas123
Jul 14, 2015 04:29 AM
87blyota
Jul 10, 2015 04:31 AM
icentropy
Jul 9, 2015 02:12 PM
Avenged
Jul 9, 2015 07:55 AM
