RAV4 shudder/hesitation during accelleration
Old 05-13-2009, 07:01 PM
VLP
VLP's Avatar
2000 Rav4 2wd 5 speed. During accelleration (esp. out of powerband) results in a shudder or hesitation. Thought it was possibly a worn out clutch disc at first. Check engine light recently revealed restricted flow of EGR valve, that was removed and cleaned, also cleaned was the hole entering intake manifold, pipe leading to egr valve did not look obstructed. Upon startup after cleaning, check engine was no longer on. Please give me an idea of what to check next. Thanks in advance
Old 05-13-2009, 07:33 PM
VLP
VLP's Avatar
well, just took it for a longer drive and the check engine light is back on. Is there something else associated with the egr valve that needs to be gone through?
Old 05-14-2009, 07:12 PM
VLP
VLP's Avatar
no one can help then?
Old 07-15-2009, 07:32 AM
usedriceburner's Avatar
Sounds like polution control, recirculation or clogged cat. After cats go, most owners learn to live with engine light on. http://www.used-rav4.com Thanks, Mike
vanion2
07-29-2015 06:17 PM
odieduanejones
12-30-2006 01:04 PM
nhyota
7
12-28-2004 07:57 AM
Quick Reply: RAV4 shudder/hesitation during accelleration
