Problems with front driveshaft
Old 09-14-2009, 02:12 PM
KegKiller's Avatar
So I engage my 4 wheel drive for some fun on the weekend and I get a bad knocking sound from the front drive shaft. So I just popped it out to check the U joints and they all look fine. But what I did find was that ball inside the cardan? joint moves around which I think is causing the problem. Any ideas? thanks
Old 09-14-2009, 07:28 PM
myyota's Avatar
Cardan joints like u-joints can wear out, i don`t know if there rebuildable or not, because ive never had one go bad, yet.
Old 09-14-2009, 07:44 PM
82blueyota's Avatar
i just rebuit mine in my 82 it was a pita a good vise a large c clamp bfh and new ujoints from six states dist i have never done u joints befor and it was an experience.my vise wasnt larg enuf but the c clamp helped.i also replace the center ball got it from murls driveline in spokane wa nappa has them too you will need to know what size your shaft is(he he)
lledwod
08-30-2016 01:03 PM
shisha1999
03-16-2016 12:25 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Problems with front driveshaft
