Sponsored by: CARiD
Please help me with my gears
Old Sep 28, 2009 | 03:51 PM
chad1041's Avatar
Originally Posted by brian2sun
This is meant to help, not to confuse. Just so you are aware, the Tacomas and '96-02 Runners also have a 7.5" front diff, but it has reverse-cut gears. This diff is different than your front diff. Yours has a 7.5" diff w/ standard-cut gears. Your rear diff is called the 8" V6/Turbo diff.
Your RPMs will be about 5-800 higher at highway speeds if you go from 4.11s (guessing that's what you have now) to 5.29s. To give you an idea, my 4.88s made it so I do about 2700 RPMs @ 70 MPH in O/D. Not bad at all IMO. You'll lose a little bit of top-end speed, but well worth it for all the acceleration and torque you'll get back.
I say 4.88s if you're never going to get bigger tires. If you think you might, 5.29s for sure.
ok thanks thats helpful but wouldnt mine be reverse cut since its a 95.5 taco its all the same as the 96
Old Sep 28, 2009 | 04:35 PM
brian2sun's Avatar
Yes, it is the reverse-cut for you (same as the 96+ Tacos)! Sorry about that, your avatar looked like a pre-taco on my little laptop screen. I'm glad you asked again, I would have felt terrible.
Old Sep 28, 2009 | 04:41 PM
chad1041's Avatar
haha thanks a million i believe im going with 4.88 with new bearing and everything like $864 is what it just said i believe it will be a good investment
Old Sep 28, 2009 | 04:42 PM
brian2sun's Avatar
CORRECTION!!! Your rear diff is NOT the 8" V6/Turbo diff!!!!!!
It is the The T100/Tundra/Tacoma diff, which has an 8" ring gear, but it is not the same. All non-TRD Tacos came with this diff. Sorry for the wrong info, again, I thought it was a pre-Taco.
Old Sep 28, 2009 | 04:50 PM
  #25
chad1041's Avatar
lol its ok man i figured it out on the website that gear i lokked at is for like 95.5-04 tacos and i think 96-02 runners and a few more
Old Sep 28, 2009 | 05:22 PM
  #26
brian2sun's Avatar
You'll love having lower gears - it was the single best mod I've ever done for my truck!
Old Sep 28, 2009 | 05:32 PM
  #27
chad1041's Avatar
i cant wait ill let ya know when its done maybee a month or so need to get the money up lol
Old Sep 28, 2009 | 06:29 PM
  #28
yoder519's Avatar
check marlincrawler.com and trail-gear.com. you can buy the whoel 3rd with the gears already setup. it would probably be cheaper to buy the whoel third and bolt it up yourself the nto buy the gears and let a shop do it. also, yo migh twana think about throwin a lockrite or another locker in the rear while your at it.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
