Please help me with my gears
ok guys i have searched over and over if yall could help by answerin or by helping me find the thread i would be very thankful. i dont mean to get on anyones nerves just couldnt seem to find an answer that was good for me. ok i have a 95 tacoma v6 auto 3in body 3in sus. lifts runnin 33in swampers what would be a good gear to run would love to have my power back. second how can i find my axle code if my door jam sticker is gone???
yeah i need to find out what i have now i think they are 3.91 but the sticker is gone maybe due to water damage lol and by the way how would 4.88s do?
are you a 5 spd or an auto. 4.88s will be fine in a 5 spd with 33s
get your vin # and use this chart..scroll down to vin section
http://www.brian894x4.com/Gearratiosanddiffs.html
unless im reading it wrong..if so you can always spin your rear wheel once and count driveshaft rotations..for example 4 full turns and almost a quarter drive shaft rotations to one wheel rotation would be 4.10 gears
I'm running 4.10's with 35's and it sucks. You can try www.justdifferentials.com for gears and lockers...But Id check with some of the guys on here like waskillywabbit first..I like keeping my business among e-friends
This is meant to help, not to confuse. Just so you are aware, the Tacomas and '96-02 Runners also have a 7.5" front diff, but it has reverse-cut gears. This diff is different than your front diff. Yours has a 7.5" diff w/ standard-cut gears. Your rear diff is called the 8" V6/Turbo diff.
Your RPMs will be about 5-800 higher at highway speeds if you go from 4.11s (guessing that's what you have now) to 5.29s. To give you an idea, my 4.88s made it so I do about 2700 RPMs @ 70 MPH in O/D. Not bad at all IMO. You'll lose a little bit of top-end speed, but well worth it for all the acceleration and torque you'll get back.
I say 4.88s if you're never going to get bigger tires. If you think you might, 5.29s for sure.
