Sponsored by: CARiD
pic of 85 efi motor top and big yellow screw vacuum port?
Old Jan 23, 2012 | 09:23 PM
Whitie's Avatar
Hello all
First question
Does anyone have a good pic of the top of there early 85 efi motor, the po left everything amess and i want too bolt everything down back orig aka vacuum lines and such
Second
The big white or yellow screw right next too the E and F on the top of the motor has a vacuum port on the bottom (where does that go too)? Mine is open but truck runs and I want too go in for smog check CA. So have too button up.
Third
My 3 in ish front lift seems too be rancho and its very stiff
what do you think about removing a leave and adding a longer front shackle(cheap easy, could make it flex and have same lift too match rear 63 chevies)???
Thanks
Old Jan 23, 2012 | 10:37 PM
russ_'s Avatar
Here's what I have handy. If I get home from work before dark tomorrow I can try to get you a better one.
Old Jan 24, 2012 | 12:10 AM
Whitie's Avatar
Thank you ,Thank you can you answer the second question the pics are great not the top one but the lower lower one thanks
Old Jan 24, 2012 | 12:11 AM
Whitie's Avatar
Nice and clean orig looking Very nice!!
Old Jan 24, 2012 | 05:44 PM
Whitie's Avatar
thanks little hose swappin and passed calif smog with way under limit numbers... well a new cat and a o2 sensor did not hurt either
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
87turboPA
Jul 12, 2015 07:49 AM
AaronM
Jul 8, 2015 07:15 PM
toyoda8488
Jul 5, 2015 10:18 PM
