pic of 85 efi motor top and big yellow screw vacuum port?
Hello all
First question
Does anyone have a good pic of the top of there early 85 efi motor, the po left everything amess and i want too bolt everything down back orig aka vacuum lines and such
Second
The big white or yellow screw right next too the E and F on the top of the motor has a vacuum port on the bottom (where does that go too)? Mine is open but truck runs and I want too go in for smog check CA. So have too button up.
Third
My 3 in ish front lift seems too be rancho and its very stiff
what do you think about removing a leave and adding a longer front shackle(cheap easy, could make it flex and have same lift too match rear 63 chevies)???
Thanks
First question
Second
Third
Thanks
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
toyoda8488
Jul 5, 2015 10:18 PM
