Sponsored by: CARiD
Only VSC trac light on 05 Rav4, changed gas cap
Old Sep 29, 2012 | 11:57 AM
JLawrence's Avatar
Toyota 2005 Rav4 - My VSC Trac light is now on. Before this, I had both the Engine Check Light and the VSC Track light on at the same time. I checked the codes at Advance Auto and Auto Zone. It gave me a code with 3 things, Emission Control Valve, Emission Solenoid Valve, or the gas cap is not sealing correctly. I looked at the gas cap and the gasket was flat on one side so I replaced the gas cap. i then took the negative battery cable off for 30 minutes to clear the codes, then reconnected the battery cable. Momentarily no lights were on, the Engine Check Light was now off. I started the vehicle. The vehicle was not driven then the VSC Trac light came on. I took the vehicle to Advanced Auto to read the codes and there were none. How do I get the VSC Trac light off? What is the problem now?
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
msane99
Jul 11, 2015 08:08 PM
smiley52
Jul 11, 2015 05:16 AM
