Sponsored by: CARiD
Once and for all!!!-oil pan gasket or no oil pan gasket
Old Jun 3, 2010 | 02:07 PM
ehertz's Avatar
Old Jun 3, 2010 | 02:20 PM
TOYOTA 1's Avatar
Originally Posted by ehertz
would the Toyota FIPG be ok for the head gasket/intake too or would I use something different?
yes..
im sure you know but, the only place that gets silicone on the head gasket is where the head meets the timing chain cover.
Old Jun 22, 2010 | 01:35 PM
MortonPhotographic's Avatar
I used Ultra Grey in everything, timing chain cover, rear head plate, rear main seal cover and I will use it on my oil pan. My engine builders told me to use it over the black and on the package the grey appears to be slightly superior--compare them at the auto parts store.
The FSM shows how to use the sealent with no gasket. I was going to use the gasket anyway, but after reading this thread I think I will go just RTV.
Here is a link to Ultra Grey http://www.permatex.com/products/Aut...sket_Maker.htm
And here is one to Ultra Black http://www.permatex.com/products/Aut...sket_Maker.htm
They Grey had me at "premium RTV gasket maker exceeds manufacturers' performance requirements."
Old Jun 30, 2010 | 03:06 PM
KODE's Avatar
i use the right stuff 1 minute gasket maker by permatex. awesome stuff!!! oil and coolant resistant too! the good thing about this gasket maker is that you dont have to wait 24 hours for it to cure.
Old Jun 30, 2010 | 03:47 PM
  #25
brian2sun's Avatar
I used Permatex "the right stuff" on my oil and tranny pan and it's as good as the Toyota FIPG for 1/2 the price and like KODE said, it's much faster drying. Mine was 5 minute stuff though, 1 minute is too fast for an oil pan.
Old Jun 30, 2010 | 03:51 PM
  #26
xxxtreme22r's Avatar
I tell you what, I am so upset I used a gasket on mine that came with the ENGNBLDR kit. was leaking bad within the first 1500 miles on rebuild. RTV all the way, but be careful with the bead if replacing pan while engine block still in truck. 92Toy can confirm this.
Old Jun 30, 2010 | 03:55 PM
  #27
92 TOY's Avatar
yes i can........any lateral movement will "plow'' the FIPG and cause an thin area.......and then a leak.....small in my case and only in one spot.
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
