Sponsored by: CARiD
Oil Pan Removal
Old Sep 19, 2014 | 12:26 AM
anndel's Avatar
Oil Pan Removal
I'm working on a 1993 4x4 22RE p/u and need to remove the oil pan. Can I unbolt the front diff at the 3 points - 2 vertical bolts and 1 horizontal bolt and lower the diff to remove the oil pan or do I need to remove those 3 bolts plus disconnect the driveshaft and the vacuum ADD lines? BTW, it has IFS.
Thanks
Old Sep 19, 2014 | 01:29 AM
JasonYota's Avatar
You might be able to squeeze it out. I'd just drop the whole diff to give you room to work
Old Sep 19, 2014 | 07:29 AM
anndel's Avatar
OK thanks very much
Old Sep 19, 2014 | 10:40 AM
Vec's Avatar
Vec
it can be done, i just did it that way last week. i did unbolt the driveshaft from the diff and bungie it out of the way
Old Sep 19, 2014 | 03:44 PM
anndel's Avatar
And did you unbolt both side axles?
Thanks
Old Sep 19, 2014 | 04:14 PM
Vec's Avatar
Vec
Thanks
no, i just dropped the diff till the axles were on the lower control arms and worked the pan down and towards the rear of the truck, then i unbolted the pick up tube and removed it for cleaning.
Old Sep 20, 2014 | 09:31 PM
anndel's Avatar
Ok thanks very much for the great advice.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
ryerye13
Jul 14, 2015 08:27 AM
HRDC0R19
Jul 5, 2015 06:43 PM
