Oil Pan Removal
Oil Pan Removal
I'm working on a 1993 4x4 22RE p/u and need to remove the oil pan. Can I unbolt the front diff at the 3 points - 2 vertical bolts and 1 horizontal bolt and lower the diff to remove the oil pan or do I need to remove those 3 bolts plus disconnect the driveshaft and the vacuum ADD lines? BTW, it has IFS.
Thanks
Thanks
Sep 4, 2015 09:27 AM
