Sponsored by: CARiD
Oil in antifreeze?
Old Dec 5, 2011 | 01:12 PM
joeymmeezz's Avatar
Oil in antifreeze?
I poped open my radiator cap and found oil in their
Is it a blown head gasket?
Old Dec 5, 2011 | 01:19 PM
delmert's Avatar
Very very very likely... does your oil also look like choclate milk?
Could also be a cracked head.... niether of which are good at all - sorry...
Old Dec 5, 2011 | 01:58 PM
OrRunner's Avatar
or a worn timing cover...If its a 22re, is also a possiblity
Old Dec 5, 2011 | 02:08 PM
James Woods's Avatar
Do a search, one of the most common problems with 22r style engines is that the plastic timing chain guides break and then as OrRunner said it wears through the timing cover and mixes oil and coolant. But it would help a lot if you started with letting everyone know what engine we are talking about.
Old Dec 5, 2011 | 02:37 PM
joeymmeezz's Avatar
I have an 84 4runner 22r
Old Dec 5, 2011 | 02:40 PM
OrRunner's Avatar
when was the timing done last? new cover or old? hows the power on the truck? white smoke out the pipe? lots of things to narrow down what it "could be"
I'd compression test it I guess. That should let you know if its in the head and or gasket. If your numbers are good, I would do the timing with a new cover and run it.
Start with the cheaper less time consuming things and work your way into the motor, but don't be lazy on the fix. If your in the timing components and take the cover off and there are no marks or worn components then get into the head.
Just my .02
Old Dec 5, 2011 | 02:45 PM
joeymmeezz's Avatar
I dunno I bought the truck 5 months ago and the power of the truck has been very low lately and white smoke dose come out when I start it
Old Dec 5, 2011 | 02:49 PM
creswellhick's Avatar
ya head gasket lol or just cracked head
Old Dec 5, 2011 | 02:50 PM
Simple way to tell, pull the valve cover and look down at the guides to see if they are broken.
https://www.yotatech.com/forums/f116...cement-212688/
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
calderp
Jul 27, 2015 09:58 AM
kcaudill
Jul 20, 2015 12:06 PM
Jonny246
Jul 12, 2015 04:51 AM
