Sponsored by: CARiD
Odyssey Battery Question
Old Mar 6, 2010 | 01:33 AM
el_taco's Avatar
truck: 2001 taco 4x4
just landed a brand new odyssey 34/78 1500 battery for a hundred bucks, local.
the guy said that the battery was sitting in his garage for a few months (maybe 2-3 months).
when i checked the battery with the multimeter, it reads 10.6 and later 10.3. seems like its dropping.
is this normal??? <<< because its been sitting around and "discharging"???
if so, how can i charge it???
thank you all.
Old Mar 6, 2010 | 05:42 AM
94svt50's Avatar
Sounds low on the voltage. Take it down to the local auto zone or advanced auto, if they have them in your area, they can test the battery to see if its even a good battery and they can also charge it for you over a several hour period. You could just stick it in the truck, jump it if needed, then drive around till charged.
Old Mar 6, 2010 | 08:35 AM
Firefightertaco's Avatar
yeah man its fine, its just became discharged from not being used, id just take it to like auto zone and they can put a heavy amp charge on it from there charger if you want it normally takes like an hour if there not charging any others first.
Old Mar 6, 2010 | 08:37 AM
sovereign's Avatar
I left a Diehard P-5 (Odyssey rebadge) for exactly 6 months off charge. It still read 12.3v when I hooked it back up. You should have that one tested.
Old Mar 6, 2010 | 04:06 PM
laskt9's Avatar
94svt50- driving around and letting your alt charge the battery is a horrible idea. Not only can it not charge the battery fully. it will also kill your alternator.
Also your battery should not discharge while sitting. Clean off the battery posts and put it on a trickle charger
Old Mar 6, 2010 | 05:58 PM
94svt50's Avatar
I disagree, It can and will take a battery from flat to charged through the course of several driving cycles. And how can the alternator doing its job destroy it? It doesnt know if the battery is completely dead or just run down from a bit of cranking.
Old Mar 13, 2010 | 01:17 PM
laskt9's Avatar
you would be pushing the alternator to work at full strength for an extended period of time, thats going to create alot of heat. heat will damage the solder joints inside the alternator along with the insulation and brushes. it might not kill it right away but its going to shorten the life of it significantly. do you have any experience rebuilding alternators?
Old Mar 13, 2010 | 05:31 PM
el_taco's Avatar
thanks.
no experience in rebuilding alternators.
i have the battery on trickle charge and its holding just about 12.60ish-12.65ish, but if i leave it overnight without the charger, it SLOWLY discharges to about 12.58ish range, VERY SLOWLY discharges and does not hold at 12.65-67.
i was thinking about charging it so i can start the truck and then drive so the alternator "charges" the battery. <<< some say yes and some no to this.
recommendations???
Old Mar 14, 2010 | 05:21 PM
laskt9's Avatar
have you cleaned off the battery top? it will discharge if there is dirt there.
if the batter is around 12.5 you can let the alt charge it but i wouldnt do much more than that as it will burn up stuff inside like i said before
80Truck
Oct 12, 2025 07:25 PM
SubiKing
Aug 21, 2021 03:57 AM
makemusic116
Aug 2, 2015 04:40 AM
stock87yota
Jul 31, 2015 10:08 AM
mluz013
Jul 24, 2015 12:31 PM
