no brakes
just recenlty changed the drivers rear wheel cylinder. so im going down the road about 40 mins i stoped at micky d's notice white smoke but i thought it was this ugly gmc'[s exhaust. turn's out the oil cap some how came unscrewed and popped off.
oil every where checked fluid's everything is fine but no brakes e- brake barely holds haven't found any leaks either
So, if the oil spillage is connected to the loss of brakes then you have oil all over the brake pads, spray down with brake cleaner untill fixed. If the oil spillage is a cosmic fluke that just happened at exact momment of brake loss, then you must have air in the lines from the wheel cylinder install. But, since the e-brake does not work, you probably have a good coating of oil on every thing. Take it apart and have a look.
changed the cylinder, had a broken spring on the drivers side. fixed and bled brakes still no brakes took off master it was filthy as hell inside and gunky cleaned and nothing.
last place is the master before i tear off the brake lines. they get hard and build up pressure but still go all the way to the floor. no leaks any where
1uzRunner
63
Nov 10, 2018 03:58 PM
