Sponsored by: CARiD
Newbe Here 22r basic wiring to get it started
Old Mar 16, 2011 | 02:38 PM
crazydaydayftp's Avatar
I put a 22r in a geo tracker...The tracker did not have any wiring in it.. I have everything hooked up but a switch for the ignition coil and distributor I tryed hooking it up with a 1979 gm ignition module the same way that it was posted on pirate4x4 and no spark out of the coil or distributor...can someone please help me or please direct me to the link
Thanks
Old Aug 30, 2011 | 01:39 AM
Tyerial's Avatar
Don't use the GM on a Toyota engine in a metro youz must be a crazy person. Lol the GM moduel needs a reference signal and two power inputs to run the coil check your grounds that's usually the problem
Old Aug 30, 2011 | 05:04 AM
xxxtreme22r's Avatar
are you using a GM coil or the 22r coil? Because with the GM ign module your supposed to use a GM style coil.
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
marcusSRG
Jun 27, 2015 07:13 AM
newzingo
Jun 24, 2015 01:50 PM
