Sponsored by: CARiD
New to me 86 toyota pickup.
Old Feb 16, 2010 | 06:42 AM
Brian88's Avatar
The other day i picked up a 2wd pickup with the 22re cheap because it doesnt run. I traced it down to the motor is not getting fuel. Itll run if you spray fuel into the intake and if i hook up a jumper wire to the fuel pump the pump will get fuel to the rail, dont have a gauge to check pressure, but it will only run till it burns through the fuel sprayed in the intake.
Old Feb 16, 2010 | 05:21 PM
myyota's Avatar
Next to the AFM is a conector and if you jump those two wires the fuel pump will run as soon as you turn the key on, try that and see if it will start.
Old Feb 18, 2010 | 05:30 AM
Brian88's Avatar
Ill give it a try and let you know, thanks.
MO transplant
Apr 23, 2023 11:58 AM
Regency
20
Jan 3, 2020 07:43 PM
Sep 4, 2015 09:27 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
