Sponsored by: CARiD
new here, rough idle
Old Mar 6, 2013 | 05:19 PM
89blaster89's Avatar
hey guys im new here, i just joined, ive been lurking around here trying to find the problem to my rough idle. it seems like when its cold it will start up just fine and idle fine but after about 5 minutes of idleing when its warm it starts to idle rough and very low and then it eventually dies, but it will start right back up most of the time but once in awhile it will just keep cranking and not start. i just replaced the alternator in it and also while i was reading i read that it might be a leak in the tube from the Plenum down to the Air Valve, what exactly is that? where is it? by the way its a 93 toyota 2wd pickup 22RE 4 cylinder. any help is appreciated
Old Mar 6, 2013 | 07:34 PM
anyone???????????
Old Mar 6, 2013 | 07:57 PM
Markarino's Avatar
Sounds very similar to what I had in my previous 22RE before I moved into the 3VZE territory. My original 22RE had some horrible internals due to bent valves and a leaking head gasket before blowing. Regular maintenance like cap, rotor, spark plugs, plug wires, checking for vacuum leaks is always a good start. If all those are in check see if the TPS is out of sync. Start with the easy things before diving else were.
Old Mar 6, 2013 | 08:10 PM
cool, yeah im buying plug wires and plugs and a nice oil change tommorow but what exaclty is the cap and rotor? sorry im new to the 22re engine never have owned one until now. also sorry for the rush but this thing is my daily driver and im not to crazy about riding the school bus haha
Old Mar 6, 2013 | 08:26 PM
HunterRunner0122's Avatar
Welcome to Yotatech!
This is what the cap and rotor look like. Its part of the distributor. It's a good idea to replace them when u change ur plugs and wires.
Old Mar 6, 2013 | 08:41 PM
Attachment 91315
thanks, yea i just called the auto store and the rotor is only like 5 bucks so thats good but they didint have caps in stock? my current cap is a bosch anyone know if thats stock on these things? and is there a certain brand of plugs that are good to get or to stay away from? im on a budget so dont have alot to spend. thanks again
Old Mar 6, 2013 | 08:52 PM
I believe Denso is the factory part for the cap and that's what I would replace it with. I would go with NGK plugs or Denso.
Old Mar 6, 2013 | 09:08 PM
cool thanks, is there anyway to tell if the cap is bad? how does the cap and rotor go bad? what wears out on it?
Old Mar 7, 2013 | 06:54 PM
got a new problem, after installing the alternator the belt squeaks pretty loud at low rpm's, the belt is pretty tight, just tight enough so it has about 1/2 inch of slack
Old Mar 11, 2013 | 04:00 AM
SPARKS89's Avatar
They just wear out. Every time the rotor comes in contact with the next point on the cap you get a small arc and over time those arcs add up and it just slowly burns it away. You have to replace them every so often so the electricity can still get a good path to the plugs.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
1992pickupSr5
May 9, 2019 08:44 AM
TACOJO
Nov 27, 2015 05:26 PM
markwink
Aug 18, 2015 12:38 PM
