Sponsored by: CARiD
new 02 4runner
Old Sep 11, 2006 | 09:29 AM
shyogy's Avatar
new 02 4runner
I just bought a new 02 4runner but when I went to the dealer to drive it they had it in 4low with the center diff locked. They said they were just checking to make sure everything was working after recon. How concerned should I be? I know it shouldnt be driven on dry pavement like that.
Old Sep 11, 2006 | 09:46 AM
pat161's Avatar
I wouldn't be concerned at all, if it rides fine then it is fine. Having the truck in 4wd w/ the center locked on pavement won't always damage things. The problem is binding going around corners and such. You could put your truck in 4lo w/ the center locked and drive 100 miles on pavement, as long as you don't turn. I was pulling out of my sisters yard in my Tacoma, I was in 4wd so as not to wreck the grass, I forgot to put it into 2wd and it bound pretty bad as I cut the wheel to turn onto the street, but once back in 2wd it was fine, had I kept driving like that it could have been an issue, but just a little bit won't hurt things.
Old Sep 11, 2006 | 11:34 AM
Elton's Avatar
Welcome to YotaTech.... im sure they didint go pavement wheeling with it all they do is check to make sure the lights come on and drive it like 10 feet in 4wd to make sure it all works
Old Sep 11, 2006 | 11:54 AM
SoiledGreen98's Avatar
I drove mine for a week in 4-hi before I knew it was in gear. Didn't learn that untill I went off-roading. Luckily nothing got jacked up. I'm sure yours is fine, just check like Elton said.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
