Sponsored by: CARiD
my first 86 4runner
Old Jul 13, 2008 | 04:51 PM
scuba's Avatar
Originally Posted by 874runnersr5
hmm thats weird, il try to figure it out
wait, forgot to mention
this site helps alot if you already havent looked at it
http://www.off-road.com/toyota/tech/codes/index.html
Original poster, your gonna have to slow down.
read this ^ page, if you have a code 12, it will be....Blink pause Blink Blink.
If you have to take a video of it and post it up.
Old Jul 13, 2008 | 05:28 PM
874runnersr5's Avatar
^bingo
that page helped me out alot, even thoe the fsm didnt have the code i was getting this site did
Old Jul 13, 2008 | 07:02 PM
1st Toyota's Avatar
OK I got a video in MOV form but I am also kind of internet illiterate and don't know how to upload it.
Old Jul 13, 2008 | 08:36 PM
1st Toyota's Avatar
http://www.youtube.com/watch?v=xa3q80hfbp4
THERE IT IS =)
Took me long enough.
Old Jul 13, 2008 | 09:58 PM
  #25
CyMoN's Avatar
try it with out the truck running that might be part of your problem of a weird code
Old Jul 14, 2008 | 11:55 AM
  #26
1st Toyota's Avatar
I know thats what I'm supposed to do but the one time i tried that nothing came up. But I'll see if anything's changed.
Old Jul 14, 2008 | 02:00 PM
  #27
1st Toyota's Avatar
http://www.youtube.com/watch?v=ppnBem_IOak
there it is with the rig off. Hope that'll help
Old Jul 14, 2008 | 02:17 PM
  #28
904_runner's Avatar
If you look back at cymon's post where he included the pic of the FSM (factory service manual) that looks like there is no code to me.
Old Jul 14, 2008 | 02:28 PM
  #29
1st Toyota's Avatar
I don't understand why it's running so horribly then.
Guess I'm stuck paying the $125 for a mechanic to scope it out for me.
Old Jul 14, 2008 | 06:33 PM
  #30
CyMoN's Avatar
this is a silly question but have you replaced the fuel filter.
and have you disconnected the battery from the last time you jumped the codes
if you have it will reset the codes if you have disconnected the battery then you will have to take it back out until it acts funny then check the codes.
I would also check all of the vac lines and the intake hose in between the throttle body and the airflow sensor.
my theory is if the rubber has a crack on any parts of the intake and the motor gets warmer the rubber gets softer and if it has a crack it could open witch would make it run bad .
I had the reverse thing where when I would start up the 4runner in the mornings it would run like crap once the rubber hose got warm it would seal its self up.
I would also check all of your grounding wires I ran into a sloo of frustration because of one wire it took me 3 trys to get it clean and grounded.
Old Jul 14, 2008 | 08:43 PM
  #31
yeah, do the basic checks if you already havent
air filter, spark plugs, wires, everything basic.
Old Jul 15, 2008 | 07:15 AM
  #32
1st Toyota's Avatar
I just found out even worse news.
It has a blown head gasket. I went to do the oil and filter change and my oil is very very runny.
Old Jul 15, 2008 | 07:33 AM
  #33
904_runner's Avatar
Sorry to hear that, All i can say is at least its not the 3.0.
Are you planning on fixing this yourself?
Old Jul 15, 2008 | 09:39 AM
  #34
CyMoN's Avatar
is there oil in your coolant?
make sure that the timing chain did not wear a hole into the water pump if you did a compression test and all 4 cylinders are at 150 then I highly doubt that your head gasket is blown.
Old Jul 15, 2008 | 10:07 AM
  #35
1st Toyota's Avatar
Well I changed the oil to check if it gets water in it again, let it run for 15 minutes then checked it and no water. Now I'm confused. And theres no oil in my coolant. But there is a slight knock so I guess I'll try and find a cheap rebuild kit, ANY SUGGESTIONS on where to get one online cheap?
Old Jul 15, 2008 | 10:11 AM
  #36
904_runner's Avatar
UOA? Ive been wanting to get one done, but maybe you should!
"used oil analysis"
Old Jul 15, 2008 | 10:41 AM
  #37
1st Toyota's Avatar
I am very new to heavy mechanics. I can only do basic things such as brakes, rotors, transmission fluid & Gaskets. But I'm going to try and get some help and I'll take some pictures while rebuilding the piece of thing that used to be called an engine sitting in my truck. But if anyone knows where to get a rebuild kit under $300 that'd be cool because I found one here for under $300 - http://www.22re.com/main/toy/complete_22r_kit.htm
Old Jul 15, 2008 | 10:45 AM
  #38
83's Avatar
83
Try www.engnbldr.com. I've been working with him a ton and he's a great resource and has very good prices. Answers emails usually within 15 minutes but pretty much always within an hour.
Old Jul 15, 2008 | 10:50 AM
  #39
904_runner's Avatar
not, sure what brand that is, they say quality Japanese parts.
Best would probably be toyota rebuild kit.
Old Jul 15, 2008 | 02:05 PM
  #40
1st Toyota's Avatar
Well I guess the grandpa who checked my cylinder pressure didn't check cylinder #4 -.-
Because I just went to re-check them just in case and there is spark going to it and everything but no pressure. I will need to rebuild for sure now...unless I can find pistons and rings and just do those. probably better for complete rebuild though right?
