Leaking rear differential
Old 03-31-2012, 02:59 PM
  #61
cap85's Avatar
alright. thanks..where would the abs sensor be?
Old 03-31-2012, 03:15 PM
  #62
4Crawler's Avatar
Good write-up on pulling the 3rd:
- https://www.yotatech.com/forums/f116...p-pics-179241/
If you have ABS, the rear axle sensor is on top of the 3rd:
Old 03-31-2012, 03:25 PM
  #63
cap85's Avatar
alright, cool thanks! the more info and pics and opinons, the more i learn even if its a bit overwhelming at first
Old 04-01-2012, 03:30 PM
  #64
GuitarMike's Avatar
Hey, not 100% on-topic, but was mentioned above - where are you guys getting the 10mmx1 caps for your brake lines?? NAPA doesn't carry 'em, at least not up here. I could really use some! Seems like every job I have to do requires removing lines, and I am getting SICK of draining the MC...
Thanks!
Good luck with the Diff. seal - doesn't seem to bad a job for ya.
Old 04-01-2012, 04:40 PM
  #65
4Crawler's Avatar
Usually you can use some vinyl vacuum caps that fit snugly over the end of the brake line.
Or, we make some M10x1 caps, male and female:
Old 04-02-2012, 03:55 AM
  #66
GuitarMike's Avatar
Thanks, 4Crawler. I'll let you know if I can't find anything local that I can "mod" to do the job...
Old 07-11-2012, 12:03 PM
  #67
Will Holden's Avatar
4:10 vs. 4:56 vs. 4:88 on 31x10.50 tires need help...
Not sure what to go with would like to hear from owner's and there experience what works best there dislikes and like. Thanks Guys!
Old 07-11-2012, 12:08 PM
  #68
4Crawler's Avatar
Well, the factory put 4.56 on trucks with the 31" tire option that had manual transmission and 4.88s for the automatics.
Old 07-11-2012, 10:20 PM
  #69
Utah4Runner86's Avatar
I've got a 22re automatic on 31s and the 4.30 stock gears suck. It's driveable, but it struggles up hills and in headwinds, and if you can afford to regear I heartily recommend it.
jerusry
10-19-2015 05:28 PM
Iceman4193
07-15-2015 04:48 PM
andrewtexas123
07-14-2015 04:29 AM
Avenged
07-09-2015 07:55 AM
AaronM
07-08-2015 07:15 PM
Quick Reply: Leaking rear differential
