Sponsored by: CARiD
Leaking Oil
Old Oct 5, 2009 | 01:50 PM
riftfxs's Avatar
Question Leaking Oil
So i have an 88 toyota pickup. So i dont have any visible oil leaks, i have looked everything over and i dont see anything that is leaking.(and yes i know what im doing and looking for) but i am needing to add half a quart every week to two weeks. so i was wondering if the first place to look would be the head gasket? Any ideas/help on this one??
Old Oct 5, 2009 | 02:00 PM
83's Avatar
83
First place I would look is burning oil. Worn out piston rings. Not good on a rebuilt engine with only 9k...maybe the rings never seated properly? A headgasket would be pretty crazy on such a new engine, too..
Old Oct 5, 2009 | 10:35 PM
limon32's Avatar
worn valves or rings, pretty easy to determine with a compression test.
Old Oct 6, 2009 | 01:53 PM
riftfxs's Avatar
ok sweet, ill do a compression test and see what i get. thanks!
Old Oct 6, 2009 | 06:22 PM
limon32's Avatar
Do a test on the cylinders just the way they are, then pour oil into a cylinder and test again, if your number goes up after adding oil, its bad rings, if it remains constant after adding oil and the compression is low, your valves are leaking.
jasonty
41
Dec 23, 2018 01:00 PM
Ladythump
22
Nov 9, 2015 08:53 AM
yourrealdad
Jul 21, 2015 11:13 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
