leaf spring...
leaf spring...
so i have a 91 pickup and the back is sagging like crazy...i go hunting alot and have to put alot of gear in the back which makes my tires almost rub. I've looked all over the internet for stock leaf springs and i can't find any anywhere! Any Suggestions?
thanks
thanks
AAL's with like 1" of lift, or have your springs re-arched. Maybe someone around here even has some springs for sale...
If your hard up desperate, the stealership prolly sells them, but we all know what they are going to cost at the stealership.
yeah i checked at the stealership and they did sell them but they were over $600 which is pretty rediculous when i found brand new leaf springs that gave you 4" of lift for a little less than $400...so if i can't find some anywhere else i'll have to end up getting them at the stealership
I would look at OME, they are a little stiffer than stock, but from what i have seen no where near as stiff as downey springs. A friend of mine has the downey 2" springs and unless there is 400+lbs in the bed his truck is a coverd wagon.
Brodetski
Sep 30, 2015 11:50 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
