Largest Optima Battery That Can Fit?
I have a '99 Limited 4runner and am about to buy an Optima yellow top
battery. I plan to put in a sound system eventually and am interested in the
size of yellowtop I should fit in. According to their official website, they
suggest putting the largest battery that can fit.
Whats the biggest size that can fit where the original sits without too much difficulty?
-thx
-thx
There are only two sizes as far as physical size that I know of. You should go to the optima website, make a note of the LxWxH and then go and make a measurement of your tray and the space you have, also make sure the hood will close. Then you will know what you need to do from there.....be it a different holder or a bigger tray, or not being able to use the large batt.
I can't tell you for sure since I own a 1st gen.
I'm not a big fan of systems, because they always end up being more trouble than good. and they make you're truck a target for theives. But if you do, I suggest search and read up on alternator upgrades and capacitors for your system in addition to the optima battery. You may find that you would like to run two batteries as well. Its all up to you.
You'll want a D34/78 IMO. Most Optimas will fit as most are 7"x10" and fit in the OEM tray easily.
The problem is that they are SHORT compared to a water non sealed battery so you'll need a spacer or a custom battery box/top bracket.
XtraCab
Apr 12, 2020 05:25 AM
klavender1
Aug 15, 2015 01:51 PM
