Sponsored by: CARiD
Just Got A 90 Runner, What Should I Watch For?
Old Apr 2, 2008 | 10:36 AM
Runner Toy's Avatar
Moved from a 88 Cherokee to a 90 V6 4Runner, what are the main things to watch for?
Forums are a great resource and I'm glad to move here from the Jeep world.
Old Apr 2, 2008 | 11:21 AM
fastkevman's Avatar
Take good care of the engine.
Its good and bad.....
The bad is that it is one of Toyota's worst engines ever.....
The good is that being a Toyota its still better than most other engines!
Old Apr 2, 2008 | 11:32 AM
'884Runner's Avatar
The V6 is considered notorious for blown head gaskets and valve clearance issues. However, if properly taken care of, they do just fine. For instance, my dad has a '95 with 190,000 miles and only one change of headgaskets. Mainly, if you take care of the coolant system, you shouldn't have many problems with the headgaskets. Many people attribute the headgasket problem to allowing the engine to overheat and not doing proper maintenance. Anyway, good luck and welcome!
Old Apr 2, 2008 | 11:51 AM
bigarms23's Avatar
the motor take care of it i havent had headgasket roblems on my 884runnerv6 and mine has 262000miles. the rear coils a notprious for sagging issues but when you can put a 4inch procomp lift on it on replace the rear coils with some from an 4wd f150. But have fun and enjoy your new 4runner
Old Apr 2, 2008 | 02:52 PM
olharleyman's Avatar
timing belt
tenshner
water pump
cap
rotor
plugs NGK or NIPPON DENSON
plug wires
02 sensor
cat
these are the most importent to worry about
Old Apr 2, 2008 | 07:07 PM
Runner Toy's Avatar
Thanks, I'm not scared of engine work and I see my purchase as a hobby. So a little work here and there is a chalenge I enjoy.
"Don't repair it, Upgrade it!"
Old Apr 3, 2008 | 03:19 PM
Psalm 112's Avatar
What should you watch for...??? Well If you spend too much time on here reading about all the Mods you can do, watch for your money to start disappearing!!!
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
