Sponsored by: CARiD
Injectors not opening
Old Feb 15, 2011 | 04:08 PM
chris1977's Avatar
1994 toyota 4 wheel drive its getting fuel to the fuel rail truck will start for about 2 seconds only because the cold injector sprays enough fuel into the intake to make it I do not think the injectors or opening I can hold a rag of gas at the throttle body and it will run until the rag is sucked dry I have changed relays checked the fuel pump just don't know why the injectors are not opening
Old Feb 15, 2011 | 04:13 PM
rworegon's Avatar
Ummm, have you done any recent work that have affected things? Grounds tight? All connectors properly seated? Fuses checked and good?
Old Feb 15, 2011 | 04:35 PM
chris1977's Avatar
Good Question I just bought the truck 2 weeks ago from a guy who had taken both finders, hood, front bumper all kinds of stuff was taken off the truck he claimed that he changed the timing belt and couldn't get it to start back up so he just wanted to get rid of it I got a great deal on the truck so I thought what the heck come to find out its in time like I said when I hold a rag full of gas to the throttle body it runs great just don't know what would keep the injectors from opening
Old Feb 15, 2011 | 05:03 PM
rworegon's Avatar
What relay did you replace? The COR (Circuit opening Relay)? Is everything plugged into the ECU nice and tight?
Gas in the tank? https://www.yotatech.com/forums/f116...-start-226138/
The FSM may also be helpful: http://www.ncttora.com/fsm/index.html
And, please double check the grounds under the hood....a loose or not connected ground wire can cause a whole host of headache.
Similiar problem:
https://www.yotatech.com/forums/f123...needed-221468/
Old Feb 21, 2011 | 06:13 PM
chris1977's Avatar
Wow found the cor relay had to take the glove box out and the passanger side speaker and there she was replaced it and she purrs like a kitten thank you so much for responding and giving me Ideas I hate dealing with electrical issues way too many wires for me
Old Feb 21, 2011 | 06:48 PM
rworegon's Avatar
Excellent! Thanks for posting up the resolution.
calderp
Nov 16, 2015 02:49 AM
runnermedic
13
Sep 21, 2015 05:20 PM
anniesball
10
Sep 15, 2015 05:41 PM
TOYOTASC
Sep 10, 2015 05:18 PM
EatChipsNow
Sep 9, 2015 01:25 AM
