Sponsored by: CARiD
Information about wheel sizes
Old Oct 27, 2007 | 06:51 AM
kyle450rider's Avatar
What are the sizes that fit on 1st generation four runners? I mean as far as size,bolt circle and spacing. I'm looking at some wheel and tire packages and don't know what size is for what. Little info... I'm looking at 15"x8" wheels and 31x10 tires.
Old Oct 27, 2007 | 07:06 AM
4Crawler's Avatar
6 on 5.5" bolt circle. On solid axle, stock is 3-3/8" backspacing, about 3-3/4" is the max. On IFS, 4-3/4" is stock b/s, you don't want to go much less than that. You can run 31x10.50 on the stock wheels.
Old Oct 27, 2007 | 07:07 AM
razrwild's Avatar
on a 31x10.50.15 tire
31 is your rough outside diameter meaning they're about 31" tall
10.5 is a 10 1/2" wide tire
15 would be the size of the hole in the middle so 15"
on a 15 x 8 rim
15 meaning the rim is 15" tall by itself
8 is the rim being 8" wide.
For bolt pattern our toyotas have a 6x139.7 bolt pattern which is 6 lugs (holes for the studs) x 139.7 being 139.7 mm from one wheel stud to the opposite side wheel stud
hopefully this helped you out
Old Oct 27, 2007 | 09:29 AM
thanks for the information. I have been looking all day at tire and wheel packages.
coffey50
Jul 28, 2015 10:55 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
colasurdo
Jul 18, 2015 07:06 AM
Yotoder865
Jul 9, 2015 07:51 PM
