Sponsored by: CARiD
im new here and need a lift
Old Jan 29, 2010 | 06:48 PM
pandaman's Avatar
hi to get started, im dean and i just picked up a 3rd gen limited 4runner for dirt cheap and am in need of a lift so far what ive done is swapped to 15 inch rotors and calipers and threw on some 33/12.5/15 km2s and did as much trimming as i could but it still rubs on the floorboards so in the end im gunna need some sort of lift. so whats the best lift for its money. ill be doing more high speed stuff then crawling in this rig.
Old Jan 29, 2010 | 07:28 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
Welcome to the forum.
Try using the search function, your questions should be answered through that.
Old Jan 29, 2010 | 08:18 PM
4 r u n n e r's Avatar
thats a nice ride you got there. Let me know if you find anything cause im looking around for a lift also!
Old Jan 29, 2010 | 09:10 PM
MKtaco_98's Avatar
http://www.toyteclifts.com/index.php...mart&Itemid=72
i recomend toytec although im not a huge fan of spacers its still a 3" lift for $300 front and back or you could go OME you will find alot of 4runners on here go that route little more pricey but atleast its not spacers
Old Jan 29, 2010 | 09:40 PM
g_cali's Avatar
If your on a really tight budget you could get 1.5"-2.5" coil spacers for pretty cheap.
Old Jan 30, 2010 | 07:21 AM
93yotaSR5's Avatar
or if all your looking for is tire clearance, you can do a 1-3" body lift. that way you keep the stock suspension geometry. check out 4crawlers website. 4crawler.com
Old Jan 30, 2010 | 02:38 PM
^99runner^'s Avatar
a body lift would be better than a spacer lift if you dont want to switch out coils, which is more expensive. another option would be to go with a tire that isnt as wide, thats probably where the rubbing is coming from
Old Jan 30, 2010 | 06:55 PM
pandaman's Avatar
i really want the 12.5s to work cus they just look so much better. whats the going price on trd tundra coils
Old Jan 30, 2010 | 07:43 PM
^99runner^'s Avatar
true they do look good. i had them on my old tacoma but it was lifted more and i had wheel spacers. jus search around. your options are what was said: body lift, OME lift, or sonoran steel lift
Old Jan 31, 2010 | 06:13 PM
pandaman's Avatar
got my mind made up for now. 2 inch coil spacers and fj80 coils in the rear
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
