Sponsored by: CARiD
IFS rear VS. straight axle rear Question
Old Mar 23, 2010 | 10:14 AM
kingskippy2001's Avatar
What is the difference? I only have a straight axle rear for my '89 IFS 4runner, will it work ok? Any other related help would be nice, thank you.
Old Mar 23, 2010 | 10:15 AM
94sasyota's Avatar
yes its better then the older axle its 3in wider and stronger then the old model your one step ahead
Old Mar 23, 2010 | 10:29 AM
To clarify: I have a 1989 4runner. The ONLY rearend that I have is from a 1985 straight axle truck. Will if fit and work without problems?
Old Mar 23, 2010 | 10:31 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
IMO, the differances in axles, the SA and the IFS rears, is negligible...
And the diffs are built just like the Ford 9". And depending on year, it's rated stock at a 38" tire.
There are no problems with Toyota axles. Well, one. But you'll blow a UV joint to if you turn it hard under a load.
Please read.
http://home.4x4wire.com/erik/diffs/
Old Mar 23, 2010 | 10:37 AM
I am thinking of going with 35's glad to hear they are rated to 38's... where did you get that info?
jerusry
Oct 19, 2015 05:28 PM
msane99
Jul 11, 2015 08:08 PM
87blyota
Jul 8, 2015 09:16 AM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
