Sponsored by: CARiD
ifs differential more than 1 inch drop?
Old Dec 1, 2010 | 01:12 PM
PR_TRUCK's Avatar
Hello guys i search here and i read about the 1 inch drop for the ifs diff. The question is: The drop can be more than 1 inch to even release more stress from the cvs?
Old Dec 1, 2010 | 01:35 PM
vital22re's Avatar
totally a bro
you should not need more than 1 " even then all the drop does is space out the 2 rear mounts the front stays the same. basically the rear swivels down an inch. It causes vibration in the driveline do to change of pinion angle.
Old Dec 1, 2010 | 09:16 PM
Guyechka's Avatar
That's what I was going to say: a larger drop will screw with your pinion angle. The only reason to have a drop is if you add a lift. The purpose of the drop with a lift is to take care of pinion angle issues. You have to remember that the front drive shaft is pretty short, and any drop will seriously affect the angle.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
coffey50
Jul 28, 2015 10:55 AM
scottyg486
Jul 19, 2015 05:34 PM
