Sponsored by: CARiD
Idle poblems
Old Nov 2, 2010 | 11:54 AM
eddlg01's Avatar
Question Idle poblems
I just replace the engine on a 89 Toyota truck 3vze, it's running but it's idle to high, around 1500 RPM, the crank shaft is on the 0 position and the rotor is on the #1 spark plug position, it crank right away but it will not come down on the idle, i try to retard the timing but the truck got lousy, the timing is showing about two inches backward on the 0 mark on the crank shaft with the timing light on it and 12 o'clock on the #1 spark plug rotor. I notice that the heads were done before and the engine is in excellent running shape. I try twice removing the distributor and resetting to the # 1 position but is the same. can someone give and advice of what is going on
Old Nov 2, 2010 | 10:07 PM
bobby_duce's Avatar
sounds like you might have a vacuum leak somewhere, d let the engine run and listen with a cut up hose and see if you can hear where its coming from!
Old Nov 3, 2010 | 04:36 AM
eddlg01's Avatar
can a faulty intake gasket cause the truck to idle high, i had two bolts that were strip.
i had check all the vacums hoses and and there in good conditions
thanks ed
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
