Sponsored by: CARiD
High steer kit
Old Apr 8, 2010 | 03:23 AM
Str8Savage's Avatar
High steer kit
Sorry if all this has been asked and answered before but i got a question about high steer kits. I own an 85 longbed and an 86 ex cab that i use for parts due to cracked frame. I'm purchasing a high steer kit from addicted offroads website to fit on my 85 because i plan to go higher on my lift which is only a 4'' right now. I'm over the stock push and pull steering. Besides an IFS steering box adapter plate and some time, what else will I need to do this install?
Old Apr 8, 2010 | 03:39 AM
dropzone's Avatar
Fossilized
welcome to YT
you are pretty much on target for what you need:
Minimum 3" lift
High steer kit
IFS steering box
IFS mounting kit/adapter plate--> I suggest you use a 3/4" hole saw when drilling the frame. it took me forever using a 3/4" bit
you might find these pics helpful when you do the install:
Originally Posted by waskillywabbit
The IFS box mount is pretty simple. Cut the fender well so you can easily access the PS box area like shown in my pictures posted already and then push the box all the way forward until it is on the core. Angle it so the holes line up on the frame in the center and then test fit your mounting plates. Tack weld and test fit again to make sure the pitman arm clears and weld out.
what you don't want to have happen when you install your high steer:
Originally Posted by 98taco4x
oh and make sure that your drag link clears your tierod.
Cause you don't want this.
Old Apr 8, 2010 | 09:05 PM
ScottyC's Avatar
That is all you need.
Old Apr 9, 2010 | 02:37 AM
Str8Savage's Avatar
Much mahalo's for the info and illustrations guys. Now i just need to secure a better welder for my project and i can order my parts.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
jerusry
Oct 19, 2015 05:28 PM
calderp
Jul 27, 2015 09:58 AM
gmonnie123
Jul 26, 2015 02:44 PM
